Salta al contenuto principale
La versione con solo il Wi-Fi dell' Apple iPad Air, numero modello A1474. Disponibile nei colori grigio siderale e argento, ha un processore A7 custom ed è disponibile con memoria da 16, 32, 64 o 128 GB.
Stuck in a reboot loop I think?
So when I plug my iPad air 1 in, it goes to Apple logo then goes black, and just does this over and over. I hold power and home and it just does the same, sometimes goes into dfu mode when im holding home and power. Well you'd think I should plug into iTunes. Well sad thing with that is, it won't even power on or enter the loop or go into dfu mode when plugged into PC. Hopefully someone out there knows what to do.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
hello Benjamin,
it looks like an internal problem after unauthorized repair (quite a common case). iPads are sensitive to the lack of knowledge of technicians, which is why not many of us can work with them. If you fail to complete the restore process from DFU, please find a good repair shop. It will need knowledge and equipment to repair that I suppose you don't have.
Punteggio 0
Parti e strumenti popolari
Acquista tutti
Aggiungi la tua risposta
Benjamin Sharp sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 60
