Keeps throwing a code 2 to empty trash
Keeps saying to empty trash but there is no trash in it
Questa è una buona domanda?
Error 2 on an iRobot Roomba 980 usually means that the rubber brushes are clogged and need to be cleaned. The most likely cause is hair stuck on the brushes, which is preventing them from spinning properly.
To fix the error, you can try these steps:
If the Side Brush is not spinning after cleaning, you may need a replacement Side Brush Module.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 135
