Salta al contenuto principale
Lanciato a maggio 2020, il MacBook Pro da 13" ha dei processori quad-core Intel di ottava generazione Core i5 e i7, e grafica integrata Intel Iris Plus 645. (Modello A2289/EMC3456 con due porte Thunderbolt 3)
How difficult is keyboard replacement?
Has anyone replaced keyboard on this model already?
Can’t find any tutorial videos online yet.
How difficult is it compared to lets say unibody (easy) or touchbar (very difficult) models?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Sadly the Butterfly & Magic keyboards are not replaceable on there own! You need to replace the full uppercase assembly:
Presently we don’t have the 2020 (Magic) part info for reference here’s the 2019 model (Butterfly)
Unless you did something major to your system I would recommend you get the system serviced by Apple or authorized service center hopefully fixing it under warranty or under AppleCare+ service contract if you had it.
Punteggio 0
2 Commenti:
2015 Macbook Pros, which have Magic keyboards very like the 2020 Macbook Pro, do have replacable keyboards. It's a fairly difficult and annoying repair but you can buy a 20$ part and fix your keyboard. You'll have to remove all the rivets, but it's doable. Is there any confirmation this is not the case on the 2020 model?
da
@iphone3ghulp - The 2015 McBook Pro's use the original Scissor key switch design which the Magic key switch is based on. While very similar they are not the same keyboard design (not transferable)
So far there haven't been any replacements offered on the market for either Butterfly or Magic keyboards.
da
Aggiungi la tua risposta
Maxim Trofimov sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 659
