Salta al contenuto principale
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
The door will lock and unlock about six times
I have a 110 Kenmore top loader. I put a new lock and latch and the lock will lock and unlock about 6 times and the sensor light blinks. What do I do now?
Update (10/05/2020)
It will wash and drain it just won’t spin
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@paulabrant1961
If you are having problems with your washing machine’s lid switch, see the Kenmore 110 Series Washing Machine Doesn’t Stop Spinning When Lid Is Opened problem page for possible causes and solutions.
This sound like there is something not allowing the tub to inhale. Possibly a rusted hub. The sensor is sensing the position of the motor/alignment of the clutch with the tub and motor. If something isn’t lining up right it will try to adjust itself . That’s when you hear the lid lock clicking repeatedly. Sometimes I’ve found an item of clothing that worded its way between the inner and outer tub. Or the hub assembly is rusted to the drive shaft. Either one will require some work to remove the agitator/wash plate then remove the inner tub to inspect the hub. Both will keep the tub from spinning while everything works.
Punteggio 1
Aggiungi la tua risposta
paulabrant1961 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 106
