Salta al contenuto principale
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
Why is there an SSD temp sensor included in the kit?
Im assuming the kit has install instructions, as I can't find them here. Perhaps this part is already in there, as the SSD that just went belly up was reporting temps via iStats for years… Can anyone clarify? thx!!!
Update (10/04/2020)
Yes, but why do I need it? The installer video never mentions it. There is already an SSD in there, albeit dead.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
The iFixit SATA SSD kit does offer the needed sensor! iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
Immagine Upgrade the storage and improve boot time and read/write speed in your iMac Intel 27" Late 2012-2019 with this SSD upgrade kit.
Prodotto
$99.99
Punteggio 1
2 Commenti:
da
What SSD do you have in your system? The SATA drive guide does state you need the thermal sensor if you are replacing the HDD.
What maybe confusing you is there is a second drive possibility! Thats the PCIe blade SSD which is mounted on the backside of the logic board (great place well hidden and hard to get to) This SSD is present when you buy a Fusion Drive system or if you had ordered the system as a SSD only.
As far as needing it yes! it's needed in this series!
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
herojig sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 89
