Salta al contenuto principale
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
20 Domande Visualizza tutte
How to stop an unwanted power off post battery install?
Immediately post new battery replacement the unit starts up and operates perfectly except it will shut off every three minutes no matter what.
I have tried resetting all of the settings back to original, I have also wiped the iPad and started from scratch. None of these seems to help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Good afternoon Mark!
I have had this exact same thing happen to me on an iPad 6. I had isolated the battery through the repair and when reassembled it would not pull amps with the screen off and would restart every 2-3 minutes. I took it back apart and removed the motherboard to inspect the battery connections. To my surprise, there was a small spec of dust preventing one of the contacts on the board from getting good connection. Removed said dust, reassembled, and the device has been working ever since. I cannot guarantee this is your issue, but it fixed the one that I had!
Punteggio 0
Aggiungi la tua risposta
mark hilbert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 92
