Salta al contenuto principale
Annke CCTV has died
My Annke CCTV was working fine till I stupidly plugged a USB mini fan into it. The fan ran for about 10 minutes then stopped and now I have no power at all to the cctv.
I’ve taken board out and where the power goes in there is a large black square component. Can anyone tell me if its a fuse. The supply is 48volts. There is no continuity across this component.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @boness
TVS - This is a TBS - Transient-voltage-suppression diode
I see it is powered by an external power adaper.
Do you have a multimeter?
Measure and check on if the power adapter is giving the out correct voltages.
Punteggio 2
2 Commenti:
Hi, thanks for your reply. I have checked the psu and it is working
da
take more pics , showing up the whole mainboard.
try removing the mainboard and check if there are any burnt components
da
Aggiungi la tua risposta
Gordon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 158
