Salta al contenuto principale
Released 2014, October; Android 0S, v4.4.4, up to v5.1; 32/64GB storage and exclusive to Verizon Wireless.
Charging port not snug
The charging cable is very loose in the phone charging port. Can I get parts to replace the port on my Droid Turbo Power/
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Did you check with a different cable? micro-usb is kind of designed that the cable fails rather then port. If still problem:
Search in eBay (depends on the country)...
da
@markus2 Thanks for your answer. I have tried other cables and still have the same problem. The cables work on other phones.
da
Well then in eBay.com you can find the charging port around $4. Of course, there are perhaps no manuals for charging port replacement: Start with Motorola Droid Turbo Battery Replacement
May be it helps.
da
Aggiungi un commento
1 Risposta
You can take it to a technician for repair. Lose charging socket is a common thing and very easy and cheap to fix.
Do that before occupying yourself with installing new parts. You may not have to.
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Robert Bruns sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 104
