Salta al contenuto principale
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
Completely fuzzy/static screen on startup after SSD replacement
Please help ugh. The startup chime works. I tried starting from external drive and I don’t think it worked (screen didn’t change from this static). I reset NVRAM no change. I reseated display cables, no change.
Video: https://imgur.com/gallery/Mtim8BV
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sound like maybe you damaged the display its self and/or display cable on disassembly? If you can try an external display, that might be a good test. The fact that the machine chimes, means the digital portion of it seems happy (passed power on test).
Punteggio 1
1 Commento:
Agreed! Need to see what an external display shows to figure this out.
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Chris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 132
