Salta al contenuto principale
Unable to install OS X
I have just replaced the hard drive in my G4 with one from IFIXIT and used the guide here to do so.... It was simple following the steps, and taping the screws to the pages I printed out to follow....
anyway, the new drive is in and the laptop starts up but I cannot get it to install the OS
I have the disks labeled PowerBook G4 Mac OS X Install Disc 1 version 10.4, AHT version 2.5, Disc version 1.1. and then Mac OS x install Disc 2.
I have inserted the Disc 1 and held down the C key to boot up and it churns and then I just get a blue screen with nothing.....
I have held down the option key and then I get a choice of Installation Disk or Hardware Test, and if I select Installation, it again then churns and goes to the blue screen of nothing. If I choose the Hardware Test it tells me that it is not supported.
before I installed the new drive I had upgraded to 10.5.8 Leopard, from 10.5.6 which was running okay other than a Mail problem, and that upgrade resulted in a major crash, and then the Genius Bar at Apple Store said my drive was failing and they could not help me.
The Leopard upgrade was in part via a drop in DVD of Leopard and then downloads from Apple site... When I insert the drop in DVD now it tells me that it requires that 10.4 be installed before it can run.
What can be done to get 10.4 installed? I really wish Apple wouldn't be so piggish about making old versions of operating systems available.....
UPDATED AFTER FIRST ANSWER BELOW == Update ==
Thank you for the first answer below.... But
I am not convinced that it is a problem with the OS X discs......
I have diagnosed it thus....
On power startup I get the chime which indicates a successful hardware test.
Then I get the flashing question mark in the folder
This would normally mean either a corrupt OS installation or a failing hard drive.
When I startup holding down the option key to boot to the install DVD, I get the chime, then it reads the DVD to show the installation disc. I do not get any other options at this point for Utility or anything else... Just the install disc. After I select the installation disc and the continue arrow, I do get the Apple logo and the spinning wheel. At this point the computer has found a valid system disk and is attempting to load the OS. It is after this that it cannot read the OS, or it is missing some hardware connection to install.....
Therefore I took my old drive and put it in an external enclosure and connected via FireWire and began again. This time I get the chime, the folder and question mark, and then it recognizes the external drive and goes right to the Apple logo and spinning wheel and then runs for a bit with nothing on the screen before it suddenly goes dead.
Obviously it cannot make the connection between the OS and the drive....
I believe my possibilities are a dead new hard drive, a dead hard drive cable, perhaps a damaged logic board(oh no), or another hardware issue.
Seems to me I should be able to run some diagnostic check to figure out exactly what it is.... I am able to boot it into Open Firmware, but at that point I have no idea how to run any tests....
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Sounds to me like you have the wrong 10.4 installation disk for your machine. You can get an original from Apple for $15. Just give them your serial number. Once you have the 10.4 system on you can then upgrade it to 10.5
Punteggio 4
7 Commenti:
Further update.... Still a problem but I tried using the Software Install and Restore Disks for PowerBook G4 15-inch and 17-inch Mac OS X 10.3.4, but when this disc is in it runs and then gets a kernel panic and the black square warning to reboot..... And the hardware test on that disc is also unsupported. I don't have any other discs than these, so I will try your suggestion to get a new install disk from Apple. Thanks!
da
I called Apple at 1-800-myapple and was able to order new DVD of 10.4 but it will be a number of days before I get them even with expedited shipping.....
Meanwhile I read on another forum that the icon of the folder and question mark that I am getting when I merely turn on the laptop means that the hard drive is dead..... But it is a new 160gb hard drive from ifixit that I just installed..... Hopefully the icon just means that the drive has no OS installed yet, but can someone please advise on that? Should I be concerned that the new drive is not working????
da
A flashing question mark does not necessarily mean the drive is bad -- it can just mean it's not bootable. And a new drive is not going to be in Mac format anyway, and is going to need to be formatted via Disk Utility when you get to the screen where you're asked to select the disk to install to (on that screen, pull down the menu from above and choose Disk Utility). And since your old drive is supposedly bad, and you are likely booting with the wrong OS media (which often won't fully boot), I wouldn't panic until you get the DVD from Apple and that doesn't work either. Also, I assume you have at least 512MB in there (minimum requirement for Leopard)?
da
I do have plenty of RAM... And the discs I have are what came with it.... I ordered new install disc to eliminate the possibility of a damaged install disc..... But it does recognize the install disc.... When I put in the other PowerBook discs I have with 10.3 on them, it gives me a kernel panic because they are the wrong discs.... But what I am installing right now is the original Tiger so then I can use my drop in DVD upgrade to Leopard.
da
Obviously something is wrong. Disconnect the hard drive and see if it will boot from your original installation disk. You seem to be clouding the issue with these other disks. First you have to get a complete boot. If you can't, put it on the shelf till you do have the correct disk. Then tell us your problem.
da
Mostra altri 2 commenti
Preparati per le riparazioni future
Acquista tutti
i had to update firmwear n my new macbkpro to install 5.8 and have installed 5 .8 n my ld pwerbk G4 1.65GHz but the installatin did not install iphoto, imovie, iweb.... so im here looking for a firmwear upgrad... mabey u need that first too..
Punteggio 0
Aggiungi la tua risposta
karen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,657
