Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
boot loop after SSD install and fresh Higher Sierra
Hello,
I just installed MX500 series 500GB SSD on my A1278 -  2351.
I don’t have a back up or original boot disk. I went the the Internet recovery way and that show me High Sierra in the utility. Now, after what seemed like a good install, the computer restarted; apple logo shows up, progress bar fills about an ⅛ of the way then it reboots again, doing it over and over.
Only things I can think of is:
1) the SSD is not compatible
2) high sierra not compatible with this old computer.
What do you guys think?
Update (05/23/2020)
Thank you for the answer. Please check out this link, this shows it is compatible. And I had searched and n the crucial website before purchasing the SSD. Is there a way to make it work with my Macbook or do you think its an error on the crucial website and Ifixit.com?
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Kit
Immagine Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade kit.
Prodotto
$49.99
Questa è una buona domanda?
Punteggio 0
1 Commento
Sorry ;-{
I was aware both Crucial & iFixit have an error! I had reported it to both and still haven't been able to get them to fix their site info.
Here's what I wrote to the iFixit folks: Still listing the wrong SSD drive in older SATA II (3.0 Gb/s) systems. This is the third time I've tried to get this fixed.
Crucial had an older SSD which was SATA II (3.0 Gb/s) for some reason when they dropped it they thought the newer SSD's would still work. Part of the problem is the SATA III drive will appear to work, but as soon as you give it any heavy load the connection fails.
I have yet to get one to work in the older SATA II systems. I've had success in the newer SATA III systems and I do like the drive! It's just simply put, a fixed drive one speed and only that one SATA speed, unlike the Samsung drive.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You have a simple problem! The SSD you are trying to use is not compatible with your system! The Crucial MX500 SSD is a fixed SATA IIII (6.0 Gb’s) drive. Your system 13” MacBook Pro Core 2 Duo (Mid-2010) only has a SATA II (3.0 Gb'/s) interface.
You need either a fixed SATA II speed drive or one that has the ability to match the systems SATA I/O speed (auto sense) like a Samsung 860 EVO note the differences between the two drives specs! This one offers compatibility for SATA II
Punteggio 1
Preparati per le riparazioni future
Acquista tutti
Hi there I have the same issue with my 2011 13 inch MacBook pro, I took out the stock 500gb HDD and formated it on my Mac mini then put it back in my macbook pro then re installed Mac os high sierrra, after restarting, the apple logo appears then the bar underneath went like 1/8 of the way then it restarted again and again and again, I was just gonna use this for web browsing, what do you guys think happened? Hope someone can help me , thanks in advance guys!
Punteggio 0
Aggiungi la tua risposta
abdulahad665 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 508
