Salta al contenuto principale
7.9 inch display / Model A1454 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Is this LCD broken?
Is this LCD broken? It did this after I plugged it back in. It was working fine right before I disconnected it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yep LCD is broken. It comes down to two things most likely it was too much prying / flexing of the display when being separated from the adhesive holding it on the sides.
That’s the tricky part about iPad Mini screen replacements need to use something like a thin flexible plastic card or plastic money to separate the adhesive which avoids putting too much or any flex against the display.
Punteggio 1
Aggiungi la tua risposta
Alexandria Duncan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 67
