Salta al contenuto principale
Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Inserted Disk not Readable
When plugging in crucial 2.5 SSD to Mac to clone it says “the disk you inserted was not readable by this computer”
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I don’t using cloning software as it often doesn’t work!
Install the drive, then use internet recovery to first format the drive to GUID and then install a fresh OS on your new drive. To transfer your user accounts. apps and data over use a SATA to USB adapter like StarTech - SATA to USB Cable to connect your old drive, at the end of the OS install process you’ll be asked if you have anything to migrate over, select the externally connected drive and let is go!
Punteggio 1
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Adam Cohen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 91
