Salta al contenuto principale
This iteration of Amazon's Kindle Paperwhite series was released on June 30, 2015. The Kindle Paperwhite 3rd Generation is a 6-inch, 300 PPI reading display tablet that is Wi-Fi capable. The designated model number is DP75SDI.
Kindle Replacing USB socket by bypass inside
Hi,
I started replacing the USB socket in my Kindle but accidentally the conductor strips were thorn.
Now, I want to do a bypass and solder it directly to the right spot using thin wires.
The problem is that I can't determine where to solder them.
Could you advice me where to solder all 4 pins?
Thank you,
Erez
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You see the light coloured lines that lead to where the pads were. Scrape them until you see the copper trace then solder from there.
Punteggio 1
Parti e strumenti correlati
Acquista tutti
Old post lol. Clean the board and follow the traces. Might help someone else with a similar issue.
Punteggio 1
Aggiungi la tua risposta
Erez Lahav sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 165
