Salta al contenuto principale
La versione allargata del decimo telefono di Samsung della sua serie top S, presentato nel febbraio 2019. Dotato di Android 9.0 (Pie).
20 Domande Visualizza tutte
Is Galaxy s10 plus replacement screen waterproof?
Or should I buy silicone around the corners ?
I’ve seen some people changing the whole front screen, taking out the battery and placing into the new screen. So the new screen should have adhesive inside already?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
No phone is 100% waterproof to begin with. If you want to change the screen and frame buy a samsung service pack as it will be the same as factory.
Punteggio 2
2 Commenti:
What happens if you do not use adhesive to stick the screen back on?
da
It won’t stick
da
Samsumg S10 display replacement water proof yes ya
Punteggio 0
1 Commento:
No it’s not waterproof
da
You can buy a replacement screen aftermarket, get it with the frame. It will be waterproof if you reseal the back cover. But that depends on how good your work is. You. Have to take the back cover off to take the phone apart to replace the screen. So it all depends on who puts it back together and if they seal it correctly.
Punteggio 0
Aggiungi la tua risposta
Abbe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 4,017
