Salta al contenuto principale
The VivoBook E203MA-TBCL432B is a laptop manufactured by Asus. It has an 11.6" screen with an Intel Celeron processor and 32 GB of eMMC storage.
wihle updating bios it was damaged
i can not turn on the laptop.
how to recover dameged bios ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
You have tried this …
https://www.asus.com/support/FAQ/1040405
or
https://www.asus.com/support/FAQ/1039416
Punteggio 1
1 Commento:
computer didn't light up at all. it was dead.
i thik that i can to recovery bios from usb . but i don’t know how to do it.
da
This is a long shot. No promises.
Have you tried it with the charger plugged in?
You could also take out the battery and leave for a day and then try with just charger.
Does anything happens, lights, etc.?
Punteggio 1
2 Commenti:
i tried with charger , i take out the battery. but it not turned on at all. no green lamp. no red lamp (when charger is plugged.)
i plugged disk on key with bios file , press ctrl + home + power on (with plugged charger). but it did not turn on.
but i payd atention , wile pressing power button for 10 sec , the plugged disk on key makes one blink. what it means ?
da
Maybe someone knows where can I find the schematic of this computer (asus e203m)
da
Abcde Abcde….try this for bios update via usb:
https://www.gamersnexus.net/guides/1572-...
Punteggio 0
7 Commenti:
after this update it dead. and i can not turn it on
da
if it is truly a bios issue, you can remove the bios chip and reprogram. i have a feeling your troubles lay elsewhere. unless you have an chip reader/programmer and soldering tools, youll want to take this to a shop.
da
o.k.
bu i did not find the bios chip in this motherboard. i did not find cmos battery to make bios reset too.
da
@Abcde Abcde what is the board number? upload a picture of your board so we can assist in finding what you need. do you have the tools to complete this task? soldering station, eeprom prgrammer> if not, bring to a local shop. have you verified that there is voltage going into the device from the charging port?
da
i buy all the tools. but how can i find the bios version for eeprom prgrammer ? can i download and use the asus bios ?
da
Mostra altri 2 commenti
Aggiungi la tua risposta
Abcde Abcde sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 590
