Salta al contenuto principale
Modello A2116 / 2019 / processori i3 quad-core 3.6 GHz, i5 6-core 3.0 GHz oppure i7 6-core 3.2 GHz. Rilasciato il 19 marzo 2019.
Add an PCIe SSD alongside the existing HDD
Hello everyone, I have a an iMac 21,5 4K 2009 buy last summer with 1TB HDD and 8gb RAM (the entry level) I want upgrade my RAM and my HDD my question is possible to add alongside the existing HDD an SSD PCIe or the slot is missing?
Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
As expressed here: 21.5” iMac 21.5 (4K, 2019)
“It has a Serial ATA (6 Gb/s) connector for a 2.5" hard drive. If configured with a "Fusion" Drive or an SSD at the initial time of system purchase, it also has a PCIe connector, but this connector is not present if the system only was configured with a hard drive.”
Sadly, Apple did you in. You could upgrade the SATA drive to a SSD. Frankly, I recommend going with an external Thunderbolt drive. To get the best performance set it up as your boot drive! Hint! A RAID’ed SSD is faster than the internal PCIe/NVMe drive.
Punteggio 1
1 Commento:
Thanks for the info
da
Parti & Attrezzi Popolari
Acquista tutti
@Fbook what was your conclusion? Did you have a PCIe slot?
Punteggio 0
Aggiungi la tua risposta
fbook sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 286
