Salta al contenuto principale
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
gamecube controller drifting when I move left
I noticed that when I play super smash bros ultimate, even when i push my control stick to the right, my character goes to the left. I think it is a drifting issue, can anyone help me with this issue?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I had a Wavebird that was having the same issue. You need to replace the stickbox. You can order an aftermarket stickbox from Amazon or Aliexpress. What I prefer to do is to get a Wii Nunchuk with a good stick and desolder the stickbox. The Nunchuk and Gamecube controller use the exact same stickbox so you can simply solder it onto your Gamecube controller.
Punteggio 0
2 Commenti:
Was is the stickbox? Do I need a screwdriver to get the stickbox out?
da
The stickbox is what actually reads your stick movements. To replace it you'll need a Tri-Wing screwdriver and a soldering iron. Here's a tutorial. https://www.youtube.com/watch?v=KpZFeJU9...
da
Aggiungi la tua risposta
Pokemonman You sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 3,715
