Salta al contenuto principale
Queste guide contengono informazioni su utensili specifici per compiti come riparazione, costruzione o taglio. Puoi imparare come utilizzare gli utensili funzionanti per riparare quelli rotti.
making/replacing case for bits and tools
So i recently purchased a manta bit set and was wondering if anyone had taken the labelled foam insert from one of the bit sets and made or fit it into another form of case. I do like the case that it comes in, but i’m a tradesman and need something a little more secure/waterproof for example clips and a rubber seal. Thank you to anyone who can help me out!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
This case would fit almost perfectly, and is watertight and sufficiently robust
https://www.amazon.com/Plano-Guide-3600-...
The case the driver set comes in is 216 x 175 x 35 mm, and this Plano one is 280 x 178 x 101 mm
It is slightly oversized for the kit, but you could easily remedy that by placing or gluing in pieces of foam to fill the gaps.
Punteggio 0
Preparati per le riparazioni future
Aggiungi la tua risposta
Leo Amies sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 160
