Salta al contenuto principale
Why will hard Drive to SSD not allow for startup?
I recently took my entire Macbook pro early 2008 completely apart to see how everything ran and decided that I wanted to upgrade a couple of things. So far, I upgraded the ram which does work, however I upgraded the original hard drive on the computer to a 2.5'“ Sata 6 Gb/s SSD which hasn’t gone over very well. I transferred over all my files cloning the original drive and putting it onto the SSD, but during startup I get the prohibitory sign. I’m assuming that means there’s a boot issue. How do I solve this?
Questa è una buona domanda?
Punteggio 0
1 Commento
Aggiungi un commento
1 Risposta
Risposta Più Utile
Your SSD is not able to run in your system! Your computer has a SATA I (1.5 Gb/s) interface, The SSD you put in is a SATA III (6.0 Gb/s) drive most today are fixed speed meaning they can’t run in the older SATA I or II systems. You’ll need to return the SSD and get one that its spec sheet states clearly it will work in a SATA I system. As an example the Samsung 860 EVO SSD states it very clearly.
Punteggio 2
Aggiungi la tua risposta
Sean Stumpf sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 95
