Salta al contenuto principale
Lo Zoomer Dino Boomer è un dinosauro robot giocattolo. Numero di modello dell'articolo: 20063696-6022355, rilasciato il 7 settembre 2014.
Went dead after using wrong charger
I inadvertantly plugged my dino robot into a 12 volt aquarium charger. (Had the right end). Initially the robot's eyes lit up green then turned red and then went out after 3-4 minutes. It now does nothing. What do you think is wrong and can it be fixed? Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi,
You’ll have to open up the robot and check for any damage on the motherboard.
Look for burnt out components and / or use a DMM to check for faulty components especially around the area of the power input on the motherboard as usually this is where all the power regulation comes from for the device.
Here’s a link to the ifixit Zoomer Dino Boomer guide, which may be of some help.
If you find something amiss and aren’t quite sure, post some images back here to hopefully get more help.
Here’s how to do this. Aggiungere immagini ad una domanda
Punteggio 1
1 Commento:
Is it possible to buy another motherboard?
da
Aggiungi la tua risposta
Dan Ham sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 13
Tutti i Tempi: 378
