Salta al contenuto principale
10.1" Android tablet released in June of 2011. Samsung GT-P7510MA
Touch Screen Replacement problem
I replaced the touch screen on my tablet and now have a thin verticle line on the left side of the display. Other wise works ok.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Did you buy the LCD and digitizer unit as one or the separated version?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Tracy Walker double check your work and check the connector. Make sure that everything is properly seated and that the LCD connector itself does not have any bend pins, debris etc. if everything checks out okay then the issue is a bad LCD.
Punteggio 1
2 Commenti:
Everything looks good connector-wise. The digitizer worked fine before I replaced the touch screen; even worked ok with the old, cracked screen in place. Like you I can only conclude that in the process of changing to the new one, something occurred to damage the LCD. The connector for it was never unhooked, so can't imagine how it got damaged. ..
da
Can agree on that, something happened during the install and the lcd got damage.
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Tracy Walker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 163
