upon charging phone Galaxy A8 detects moisture
phone not charging due to detection of moisture.
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Do you live in a very humid area? Sometimes residual moisture can build up, and if the damage has already been done, that's why the message hasn't gone away. You can try powering the device down, giving a nice wipe inside with a Q-tip just to see if it removes anything, then take some rubbing alcohol and dip the Q-tip in it and try another rubbing. It could end up cleaning up some build upon those contact points. Let it dry after you do that, turn the phone back on and let me know if it starts charging.
Hello! I had the same problem some time ago. I tried the typical solution of putting the cellphone in rice and wait but it did not work. The solution of using rubbing alcohol and clean it up with a Q-tip works, but sometimes, the cellphones does not reset the state of wet and it is hard to charge it again, even when is completely dry. I needed to turn off the phone and then connect it when it was on the process on been turned on, then the test is going to be run again. Also, if you want to turn off the notification of wet charging port, you should also delete the data of the USB Settings app, inside of the Apps menu (showing the system apps).
Those two solutions helped me to fix the problem. I hope that helps you as well. The A8 is a really good device and this issue is very common but also, very easy to fix.
I've ever had similar encounters. Take many small strips of tissue paper and dab the usb port repeatedly until the strips start coming out dry. Also dab the inside of the usb cable connection point until dry. This should help.
Không nhận thẻ sim không mở camara được
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,232
