Salta al contenuto principale
Lanciato il 3 marzo 2017, Nintendo Switch è un dispositivo palmare che può essere usato con la TV o in movimento.
Hardware differences between the Switch v1 and v2?
what hardware differences are there between the v1 Switch and the newly refreshed v2 switch? Are they still using the same motherboards and are the displays compatible with each other? I am looking at repairing some broken Switches and need to know if parts can be swapped between revisions or if this is not possible. The ore detail the better and any help is greatly appreciated!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
The boards are not the same since the v2 has a newer SoC revision. Also the battery is a bit larger in capacity. Regarding the screen, I don’t think they have any reason to change the design.
Punteggio 1
1 Commento:
Can a V2 mother board install as a replacement for a v1 motherboard. In other words, are all the other parts compatible?
da
Preparati per le riparazioni future
Acquista tutti
The battery is exactly the same. The longer play time comes from shrunk chips…
Punteggio 0
Aggiungi la tua risposta
lolderp144 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,453
