Salta al contenuto principale
Modello A1418 / Fine 2012 / Processore Core i5 da 2,7 e 2,9 GHz o Core i7 da 3,1 GHz
Clean Windows installation on new SSD
Hello!
I have iMac Intel 21.5” late 2012.
My HDD is failing and I want to replace it with SSD. SSD is new and I plan to install Windows on it. I don’t want to install OS X.
I have Windows boot USB — used it before to install Windows on old HDD. The difference is, old HDD already had OS X installed, new SSD is clean.
Can I just replace hard drive, insert USB and smoothly setup Windows? Or I need to install OS X first, then use boot camp etc. ?
What are the steps?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi leo, I have an Imac mid 2011 27inch that I did exactly this on but I did not write down any steps. I ended up using OSX on the SSD. at any rate I found a few guides that look fairly decent.
https://www.intowindows.com/how-to-insta...
https://www.wikigain.com/install-windows...
One word of advice. If there is anything on that old drive you care about make sure you back it up in two places before touching the machine. I backup to the cloud as well as to a local drive.
When I installed windows 10 on the mac I simply created a windows 10 boot thumb drive and booted from that after I installed the SSD. I then let windows partition the disk and install as normal. it worked fine but I decided to go back to OSX as I did not have a license for windows and did not want to purchase one. besides I like OSX just as much as windows. I find it more stable by a long shot.
I did make a video on tearing down and replacing the hard disk on my system. I don’t remember if they went to the slim case in 2012 so if they did my video wont be much help.
https://youtu.be/vQ5sS6H1NaE
Punteggio 2
Aggiungi la tua risposta
Leo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 970
