Salta al contenuto principale
Modello A 1990 / EMC 3359. Lanciato nel maggio 2019 con nuove opzioni di processori esa-core e octa-core.
Can I upgrade myself SSD on 2019 MBP 15?
Just bought a 2019 15” MBP with 256 GB SSD. (On sale in Costco, not configurable).
Can I replace it with my older 500 GB SSD from my previous MBP?
If the answer is yes, anyone knows it it would it void Apple’s warranty?
Thanks in advance for your help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sorry, no you can’t swap out your SSD’s. While your 2015 or older Retina model has a removable SSD, the newer 2016 onward Touch Bar systems have soldered storage which can’t be altered.
But! you can remove your old systems SSD and place it within a case to use it as an external drive. That might be useful if your older system has died and not repairable OWC Envoy Pro - Portable, Bus-Powered USB 3.0 Storage Enclosurefor select Apple Flash SSDs from most 2013 to 2015 Mac Models
If you are trying to copy off your stuff to your new system there are other ways to do that YouTube - Using Apple Migration Assistant
Punteggio 6
1 Commento:
Thank you Dan for your answer.
Appreciate it very much!
da
Aggiungi la tua risposta
Saul sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 23
Tutti i Tempi: 27,830
