Salta al contenuto principale
The PowerBook G4 Titanium Series was initially announced at Steve Jobs' keynote at MacWorld Expo in January 2001.
logic boards interchangable?
I have the above machine with a defective logic board. I bought one on e bay and now am ready to install. The problem: the resident defective board is 400 Mhz and the one I bought is 500 Mhz. Will it work if I install it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Yes you should be able to swap the logic boards between the 400/500/550/667MHz VGA models. But you cannot use the VGA series with the 667/800/867/1GHz DVI units.
Punteggio 3
1 Commento:
I am replacing a PB G4 Titanium DVI 667mHz logic board with a 867mHz logic board. I also have been told that all of these DVI models except the 667 had a secondary fan, so I have ordered one of those fans, but don't have it yet. But the 887 that I have installed has no socket to plug the fan into, as far as I can see. The primary fan is plugged into a socket next to the fan itself, as was the 667 primary fan. My question is: Where does the secondary fan plug in? Please help me find the answer. Thanks, RHBernard@gmail.com
da
For the previous answerer:
lemerise
Punteggio 0
Aggiungi la tua risposta
russ heagle sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,212
