Salta al contenuto principale
Find repair information on the second generation Toyota Tacoma.
4wD indicator and 4 low lights on
Hello , 2005 Tacoma 4WD light and 4Lo lights blinking when ignition on . 4WD is in op. Plug in snap on scanner to data link port , and everything works fine , lights go out . Unplug scanner and lights flash immedialty
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Either your front add motor is bad or the 4wd selector switch is blown.
Punteggio 0
2 Commenti:
I’ll check the switch when I get home , it’s just does t make any sense that everything works as designed when I plug my scanner in , then quits when I unplug it , I’ll check the switch and the park neutral signal today
da
What was the fix? I am having the same issue right now...
da
Aggiungi la tua risposta
Sean baldwin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,191
