Salta al contenuto principale
The iRobot Roomba 770 is a cordless, autonomous vacuum that will clean your floor without supervision.
Dockin sensor on Roomba
My sensor on my 770 has been ripped off. How or where can I get that fixed.
Questa è una buona domanda?
Punteggio 0
1 Commento
Checked Youtube? Seems to be some info there after a quick Google.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@alligoodst use this video to work on it. The sensor is available at multiple sites. All you would need is an online search and select the site that is meeting your needs. Another way to get access to the sensor is by carefully removing the plastic piece on top of the bumper which simply snaps into place. Beneath that cover you find a second piece of plastic which is held in place by 6 screws. Remove those and then the cover. You should now have access to the sensor and the wiring.
Punteggio 1
Parti e strumenti popolari
Aggiungi la tua risposta
Stacy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 114
