Salta al contenuto principale
Repair information for the Raspberry Pi 1 Model B+. Released in July of 2014. Model: B+.
Raspberry pi 3B+ not overclocking
I’m trying to play raze 2 on my raspberry pi 3b+ so im trying to overclock the core speed but every time I go to raspi config and go to overclock it says overclocking is only available on pi 1 and 2 , and error on option 6 overclock. pls pls help
Questa è una buona domanda?
Punteggio 0
1 Commento
i just need at least a 50mhz boost on the core speed
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You must edit config.txt on the command line.
Do the command
sudo nano /boot/config.txt
Then add one of the text things you see here at
https://www.raspberrypi.org/documentatio...
For example, overclocking to 1500 mhz would look like
arm_freq=1500
Punteggio 0
Parti & Attrezzi Popolari
Aggiungi la tua risposta
Brayden S sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 257
