Salta al contenuto principale
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
I put the hd temp sensor in wrong.
I recently put in an aftermarket SSD into my imac with an SS+HD configuration but must of put the hard drive sensor in wrong, because the fans are going full blast. Does anyone know the proper way to connect it? Thanks@
Questa è una buona domanda?
Punteggio -1
1 Commento
Did you change the hard drive?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Fixed it, the sensor needs the black wire facing up, with the wires over the 2 pins closest to the sata/power cables. And for the last time, if your adding an ssd and keeping the appl drive, you will NOT have a fan issue.
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
ekimia1987 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 912
