Salta al contenuto principale
Can the DVD-ROM drive be upgraded?
Can the DVD-ROM drive be upgraded? That is, can I use a DVD Combo or Super Drive in the Mercury 400MHz or 500MHz computer?
Thanks for any more DVD upgrading.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sure, it can be upgraded. The problem is finding one. Here's three of iFixits: http://www.ifixit.com/Mac-Parts/PowerBoo...
Here's how to install it: PowerBook G4 Titanium Mercury DVD Drive Replacement
Punteggio 2
3 Commenti:
Thanks for your reply. I was concerned if the ribbon cable was the same for a CD-RW/DVD-RW (DL?) drive or if there was any other mechanical differences that would prevent installation. Thanks again for your fast input!
da
Oops? I ran into a stumbling block on using a Combo or Super DVD Drive in a Mercury 400MHz or 500MHz computer? The Help Page said: "A different cable is required to connect a Combo drive to the logic board.". Unfortunately, there's No Link anywhere to an explanation of where to Find such "different cables"?
Help! - Any suggestions?
da
For the correct cable contact iFixit directly here and tell them what you want to do: http://www.ifixit.com/Info/contact
da
Aggiungi la tua risposta
mrdagar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 735
