Salta al contenuto principale
Il Samsung Galaxy J2 è uno smartphone Android rilasciato nel novembre del 2016.
Why my recent apps button is worked automatically?
If I will use my mobile phone for more than 10 minutes it became very heat and the recent apps button pressed automatically. It irritates me.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
If your phone gets hot after only 10 minutes and seems to malfunction, then it may be infected with malware. Performing a full factory reset is a sure-fire way to remove malware from your phone. The reset can be done in your phone’s Settings.
Punteggio 0
3 Commenti:
It doesn't work
da
“It doesn't work” is a bit vague, please be more descriptive because I can't see what you are seeing. You said that your phone starts to overheat and malfunction after 10 minutes. Are you unable to get into your phone's Settings before the 10 minutes are up?
Being able to reach the Settings app would really help fix the issue.
da
saya sudah melakukan di hp samsung j2 saya tapi masih seperti itu
da
Aggiungi la tua risposta
Às Âsrår sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 12
Tutti i Tempi: 1,358
