How to replace hinge guard
how do you remove and place the hinge guard?
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
If you checkout the ifixit tear down of the C202 in step 8 they remove the display from the rest of the case and it looks like that plastic cover is still attached. I have seen these often as just ‘wrap-around’ pieces that can be carefully popped off of short partial shafts on either side. You should be able to flip that piece back and forth with the display detached if need be.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 430
da drmdolfan
