Salta al contenuto principale
How much needs to come out when replacing the keyboard?
I have a Mid 2009 15” MacBook Pro 2.53 GHz machine and I want to replace the keyboard. I have one at hand but there is not an instructions for it. There is only instruction for replacement of the entire upper case. How much needs to come out of the machine to get at the existing keyboard for replacement?
I’m guessing that at most, the logic board and optical drive needs to come out. I shouldn’t have to remove the display, I don’t think.
I have worked on MacBook Pro’s from 2008-9 with user detachable battery, logic board in and out, replacement of fans.
I’ve worked on Powerbook Titanium replacing the logic board, tear down and clean after juice spill when the machine as off.
I have also worked successfully on other non Mac laptops and have home build tower machines for use as web servers.
Thank you for time and attention
JK
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Here’s a video on how to replace the A1286 keyboard:
https://www.youtube.com/watch?v=4k0yDeOR...
Punteggio 2
2 Commenti:
Thank you for this Mayer;
The sound is poor in the video. The narrator isn't speaking
well enough into the mic during the taping.
And the machine being worked on has two fans.
The one I will work on has one fan. But otherwise it
appears to be similar enough.
da
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
jekillen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 108
