Salta al contenuto principale
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
should I replace the LCD or the digitizer alone?
the case is that , the imaging of the iPad is perfectly fine, but I have this difficulty in touching when touching certain parts of the screen (ex. when I am typing a message, at some point, the point where letter A, and N located isn’t functioning at all.. i need to rotate the screen for me to type the letter A and N..) should I replace the LCD ? OR IS it ok if I only replace touch pad or digitizer? pls do give me some advice
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
The digitizer has two layers which is touch screen and glass. Replacing that part will fix the touch problem.
Punteggio 1
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
French Marie Escabarte sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 81
