Salta al contenuto principale
Informazioni sulla riparazione e guide per l'iPhone 8, lanciato il 22 settembre 2017. Modelli A1863, A1905.
20 Domande Visualizza tutte
Screen change keyboard don't show up
Okay, here is the weird situation.
I changed the screen of an iphone 8, everything works perfect, customer came back, he cannot edit or add contacts because the keyboard wont show, but on everything else keyboard pops up.
Anyone know what this is?
I suspect a software issue since keyboard is showing every where else.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Try a hard reset first (See: Come forzare il riavvio dell'iPhone 8)
However I think you are correct, a software fault is the most likely cause of this and that would be fixed via an update/restore.
Is the customer on the beta program? A friend of mine is and he could only answer incoming calls, his dialer wouldn’t work until the following update was available.
Punteggio 1
2 Commenti:
Actually thanks for this, but it was me having a mayor brainfart.
I just had to double click the homebutton and exit all programs.
da
No worries, if only all fixes were that easy!
da
Aggiungi la tua risposta
nicolay.94 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 75
