Salta al contenuto principale
Introduced in 2016, the Brother MFC-L6700DW monochrome laser All-in-One addresses the business needs of workgroups with higher print volumes. It boosts printing and copying at up to 48ppm. The large 520-sheet capacity paper tray holds more than a ream a paper for fewer refills, and for additional capacity add-on trays boost total capacity to 1,610 sheets.
no power up when turn on
Not operational when turned on. Completely off
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
  1. Trace the power from source.
  2. Check the operation of the power switch (once in our office a printer’s power switch was found to be infested with ants).
  3. After that check the low voltage power supply board, if you can work out how to remove the covers.
Punteggio 0
Aggiungi la tua risposta
Roman Misandzhi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 409
