Salta al contenuto principale
Budget laptop released in late 2016 identifiable by the model number, N16Q2 found on the bottom of the laptop.
Screen will not turn
I have tried resetting the battery and it doesn't work.
I have tried with the power cord and without. The screen will not turn on. I have reset the computer several times also.
The computer works though. Because I have plugged in an external monitor and everything displayed on their fine and the computer works.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@esetch3
in a darkened room shine a flashlight at an angle against the screen. If you can make out shapes etc. It is your backlight that has failed. if it doesn't then it is possible that this is a bad display assembly.
Punteggio 3
Parti e strumenti correlati
Aggiungi la tua risposta
Ethan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 242
