Salta al contenuto principale
La sesta generazione della linea Moto G di Motorola. Questo telefono è stato lanciato nel 2018 ed è caratterizzato da una cover posteriore in vetro più facile da rimuovere rispetto agli smartphone Samsung. I numeri modello sono XT1925-4, XT1925-5, XT1925-6, XT1925-12 e XT1925DL.
How to replace the battery in a Moto G6
Most info I have seen from Motorola says this must be done by a factory certified technician, or you void the warranty.
The battery photo shows a connector on leads, so it would appear to be a simple task once the back is removed.
What is the step by step process to replace the battery?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
You can use the screen replacement guide to walk you though the steps.
A few cautions. If your phone is under warranty then this will most defiantly void the warranty. I would look into what options you have to get the battery replaced under warranty. How long have you had the device?
When taking the back off, it’s really easy to break the back glass. Use a lot of heat and take your time. A thin pick will help and be careful around the edges. Make sure the back stays hot. This will help keep the adhesive loose.
Keep track of your screws and make sure you know what goes where. Use a little heat and a pry tool to loosen the battery. Just be careful about puncturing the battery. If you can get under the battery with a pick or other pry tool you’ll be good.
Finally, you will want some kind of adhesive to put your back glass back on the phone. iFixit might have something otherwise see what you can find online.
Sostituzione schermo Motorola Moto G6
Punteggio 3
Parti & Attrezzi Popolari
Acquista tutti
https://www.youtube.com/watch?reload=9&v... this film shows step by step,
Punteggio 1
In this it shows you how. Why does my phone black out when making a call
Punteggio 0
Aggiungi la tua risposta
Dem O'crat sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 9,509
