Salta al contenuto principale
Computer portatile Dell Inspiron 15-3531 con processore Intel e display non touch.
How to replace my thermal compound?
I’ve been searching for a way to access the CPU and GPU to replace the thermal compound on my laptop, but I haven’t seen anything that shows how, even on here. Does anyone know how to do this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
Hi @kokohaishere ,
Here’s a link to the service manual for your laptop, taken from this webpage
Scroll to p.49 to view the necessary pre-requisite steps and then the procedure to remove / replace the heat sink assembly.
Once that is removed you can clean off and renew the thermal paste on the CPU/GPU etc.
You can also clean the fan at the same time ;-)
Punteggio 3
Here’s the guide for using Thermal Paste:
Come applicare la Pasta Termica
Punteggio 3
Aggiungi la tua risposta
Jayden Fox sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 11
Tutti i Tempi: 2,088
