Salta al contenuto principale
Controller LED per la Playstation 3 prodotto da Performance Designed Products, LLC con modello Numero 064-015-EU-BL.
Lost USB dongle. Can I sync to another?
I've lost the USB dongle to my afterglow controller, but I brought a used one off a neighbor and since my controller is in better condition than theirs is I was hoping to be able to sync my controller to their dongle…it doesn't seem to be working for me though so I'm starting to wonder if its even possible. There appears to be a sync button on the back of the controller though, so logically I would think it should go thru… can anyone tell me if I'm doing something wrong or if it's just impossible?
Questa è una buona domanda?
Punteggio 4
1 Commento
I have the same issue. I have an old Afterglow Dongle and a new Afterglow PS3 controller that didn't come with the dongle. BUT...they will not pair. I have tried...both lights blink, but then the controller just stops/turns off. They never go solid.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
How do I pair my Afterglow Wireless controller to my USB dongle?
  1. Plug the new USB dongle into your PS3.
  2. Now, press and hold the Home button (power button) on the controller until the LED on the USB dongle and the 4 indicator LED's on the controller are solid.
Punteggio 5
4 Commenti:
I have done this...but it never goes solid. They both blink until the controller finally turns off. :(
da
The dongle you have is for like a ps4 not a ps3 controler
da
someone; "My new TV doesn't turn on, how can I fix this?"
The Genius:
1. Plug the cable to an outlet
2. Now press the main button that's in the upper area of your remote ( On/Off power button) and wait until your TV turns on.
da
Then just change the engine.
Replace the engine if your cobtroller with that of your friend and change any other things that are weak in your friends controller with yours.it will become new as yours and in this case you can use the dongle. Whatsapp me on +233246206856 for further explanation or help. Im Shadymens.
da
Aggiungi la tua risposta
Vé Burson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 104
Tutti i Tempi: 17,462
