Salta al contenuto principale
Guide per la versione Wi-Fi dell'iPad Mini 2. Annunciato il 22 ottobre e introdotto il 12 novembre 2013. L'iPad mini 2, noto anche come iPad mini con Retina Display, ha tutti i pixel dell'iPad Air in un più piccolo fattore di forma da 7,9"
LCD replacement parts needed?
I replaced a broken screen on my ipad mini 2 the other day. Unfortunately while I was replacing it, my toddler “helped” me by placing his hand on the LCD. When I finished replacing the screen, and tried to power on, i had the white lines and black spots all over the lcd. When I went to the parts store to get a replacement LCD, there is a note at the bottom that says “LCD does not come with foam liner”.
What is the foam liner, do I need it, and where do I find one (couldnt find it listed in the parts store)??? Also, does it come with adhesive attached to it or do i need to get some (and if so what do I use, because that also wasn’t listed in the parts store)?? (Yes I know I need some adhesive strips for the screen then; I already have them in my cart lol.)
Questa è una buona domanda?
Punteggio 0
1 Commento
What store are you trying to buy the LCD from? i think the foam they are talking about is the foam around the LCD, for adhesive i believe it has 2 strips on the underside that holds the LCD to the metal plate to hold it, otherwise it has 4 screws holding the LCD to the inner frame.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Foam liner is used to seal up the space between the LCD and touch panel, without it, dust will eventually enter in between.
Nobody on the internet seems to sell original liner set and most independent repair shops simply leave them out.
Punteggio 1
Parti e strumenti correlati
Acquista tutti
Risposta Più Utile
The foam usually comes on the replacement glass digitizer not the LCD. I remove the foam on every repair I do, because my replacement glass digitizers come with them. In the past, I have also not replaced the foam and there isnt any difference that I can tell honestly.
Punteggio 2
Aggiungi la tua risposta
Janelle E Clark sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 96
