Salta al contenuto principale
Guide di riparazione e assistenza per il OnePlus 5T, uno smartphone Android con display AMOLED da 6,01". Rilasciato a novembre 2017. Successore del OnePlus 5. Numero di modello: A5010.
Issues with screen after replacing
Hello,
I'm experiencing some issues after replacing my screen. I'm getting a lot of ghost touches when scrolling, and every few days the screen goes crazy with clicks. Completely unusable. Can't do anything but hard reboot which fixes it. The Keyboard is a bit off. Most gestures work, but only if you use a different one each time. Example: You can't use 'V' twice in a row. You have to do a different gesture each time or it won't respond. Music gestures don't work at all.
Everything else works as it should.
Any idea what could be causing it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Probably needs the digitizer cable reset. Smontaggio OnePlus 5T here is the tear down video if you feel like doing it yourself. The LCD able is around 3:43. If that doesn’t do it it is probably an issue with the motherboard connector or the LCD connector itself. My guess would be that it is not seated properly.
Punteggio 0
Original screen folder Amoled
Punteggio 0
Aggiungi la tua risposta
Liam Mooney sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 10
Tutti i Tempi: 1,973
