Salta al contenuto principale
Serie di portatili HP Pavilion rilasciati nel 2015. Il modello 15-p è più difficile da riparare rispetto ai successivi modelli 15-x.
Certain Keys On Keyboard Are Unresponsive
My HP Pavilion 15-e013TX’s built-in keyboard has some keys unresponsive (A,S,D,F,J,K & L to be specific) I tried most of the things on https://au.pcmag.com/how-to/9345/how-do-... but the problem still prosper.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
Most of these are because the keyboard has failed or the connector is loose. It may work again if you reconnect the keyboard internally, but it’s generally due to a matrix failure.
In your case, you picked the wrong system :-). The 15-e has a modular keyboard, which isn’t the case on the 15-p series. Refer to the Service manual to replace the keyboard and get the part number that matches the country you are in. The US part numbers are 719853-001 or 720597-001.
Punteggio 2
You will have to change all the Keyboard
Punteggio 0
Aggiungi la tua risposta
FAMASyCoyote 358 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 20
Tutti i Tempi: 533
