Salta al contenuto principale
Dai un'occhiata a queste guide per trovare informazioni sulla riparazione e sullo smontaggio della tua macchina da cucire.
20 Domande Visualizza tutte
singer - tangles thread arond the shuttlehook\bobbit
I have a Singer machine from the 70’s (M43 looks like mine). Recently, thread keeps building up like 15 revolutions around the shuttle hook\bobbit if I sew fast.
I had a shop look at it and they *say* it is fixed but it still does the same thing. Only if i sew very slowly does the thread not wrap around alot around the the shuttle hook\boobit.
The store says it is because of the denim i am sewing but i have been using this many times before it started acting up. The store guy(who “repaired” it) adjusted a screw so that there is some tension for the thread feed from the bobbin.
TIA.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
ANYTIME THE SEWING MACHINE THREAD IS BUNCHING UP, OR BIRD NESTING, ON THE TOP OFYOUR FABRIC, THE CULPRIT HAS SOMETHING TO DO WITH YOUR BOBBIN.
1. IS YOUR BOBBIN THREADED CORRECTLY?
If your machine uses a bobbin case, take the bobbin completely out of the case and re-thread it. Be careful to follow the instructions for your machine, and make sure you have the bobbin thread engaged in the bobbin tension. A good test for this is to hold onto the bobbin thread with one hand. If the bobbin drops all the way to the floor, you missed the tension spring in the bobbin case.
2. IS YOUR BOBBIN CASE TENSION TOO LOOSE?
If you have loosened the screw on your bobbin case to accommodate thicker threads for surface design work, you might not have re-adjusted it correctly for regular thread. After correctly threading the bobbin case, tug gently on the bobbin thread. You should feel some resistance, but the thread should move freely. If you have not made any changes to this tension setting, it is likely not to be the cause of any thread bunches, as it is set correctly at the factory. If you do adjust it, be sure to do so in small increments to avoid dislodging the entire screw.
CONVERSELY, THE REASONS THAT THREAD CAN BUNCH UP UNDERNEATH YOUR FABRIC HAVE ALL TO DO WITH YOUR NEEDLE TENSION.
1. IS THE NEEDLE THREAD THREADED CORRECTLY?
Cut the thread a few inches from the spool, and pull it through the needle. Re-thread, taking care to engage the upper thread completely in the tension discs. I always suggest to my students that they hold the thread on either side of the tension disc, and slide it back and forth a bit between the plates with a flossing motion. The tension discs need to “grasp” the thread snugly.
2. IS THE PRESSER FOOT UP?
Duh. We’ve all done it!
3.  IS YOUR MACHINE CLEAN?
Frequent dusting underneath the throat plate and along the thread path will prevent all sorts of stitching and machine problems. Of course, good quality thread, a new, sharp sewing machine needle, and the correct bobbins for your make and model of sewing machine are basic requirements for producing good quality stitches. Frequent dusting, cleaning and oiling will also prevent these and many other stitching problems you might encounter.
Punteggio 2
3 Commenti:
i just cleaned my machine prior to the project I am working on that my machine decided to get wonky. I made all of the adjustments above. I have been sewing for over 40 years. Knew all of this, thought you would have another solution for a newer machine.
da
@kathietanner I'm sorry, I'm not familiar with the newer machines.
da
Check that the upper thread is coming over the bobbin case smoothly mine had a nick in it I guess from a drop to the floor, after I filled it smooth no more hang up.
da
Aggiungi la tua risposta
uncle_lee1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,195
