Salta al contenuto principale
help me undisable my iPod 3rd generation
the left slide of my ipod was froze, so i couldent put my password in. Then it became diabled an tells me to try back in 21,298,968 minutes... How do i fix it... PLEASE HELP.................
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Why is my iPod disabled for a long time?
How do I reset my iPod touch to its original factor setting?
take a look at these answers and see if they are any help. i know they are a different generation but generally the advice is the same..
Punteggio 4
8 Commenti:
+ works for me
da
+ for me too
da
So it should.... You wrote the second link!! Should get points for being linked hopefully.. Hint hint America ! If the advice on the links helps please vote them up! Cheers
da
it's all about teamwork on here...:-)
da
You're right Polly. Did you give me one?
da
Mostra altri 3 commenti
Hold the lock button and the home button until it turns off
When it's off, hold them together for 10 seconds then release the lock button. This puts it into a certain mode where it won't turn on
Then, plug it into a computer and restore the IPod
Make sure you have your data backed up because this will erase all data
Update
Watch this video if you do not understand my answer
http://m.youtube.com/watch?v=5uT8Utk5Tqg...
Punteggio 0
1 Commento:
Ryan Ckit, oh you mean DFU mode like pollytintop suggested 1 1/2 years ago....
da
Aggiungi la tua risposta
America sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,271
