Salta al contenuto principale
La seconda generazione del Recreational Active Vehicle with 4-Wheel Drive, comunemente noto come RAV4.
How do I reset the TPMS
I have 2010 RAV4 that had one TPMS-Sensor replaced. The TPMS Warning Light will not clear, even after driving 50+ miles. There is NO TPMS RESET button on this vehicle. How do I reset this ? Is there a fuse that can be re-seated? Thanks.
Questa è una buona domanda?
Punteggio 1
3 Commenti
https://www.moderntiredealer.com/article...
htt ps://w ww.mode rntiredealer.c om/article/715783/tpms-toyota-2006-2012-rav4 (remove the spaces)
AKA, go to Costco tire center and ask them :)
da
How to test the sensors and how many sensores are there in the engin of Raf4 model 2004
da
@mahaddable one in each tire and that includes the spare. That means there should be five sensors.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Is the light flashing?
Here is a video on fixing it if the light stays on: https://www.youtube.com/watch?v=kbdlypWm...
Punteggio 3
4 Commenti:
I am looking for location of TPMS RESET Button. It is not under dash, not on dash, not in glove compartment. This is a 2010 Rav4 Limited (4WD). All pressures are good. Had replaced TPMS Sensor in one wheel because it was leaking after new tires put on. TPMS Warning Light flashes when engine starts, then it stays on steady. Thanks.
da
Check the pressure in the spare tire. Tires should have min 32 PSI. See if your reset button is located under the dash, see second 18 of this video:
https://www.youtube.com/watch?v=R25t0lqU...
da
Have to register the sensor with the computer of the vehicle with some tool. ( it seems).
Go to Costco tire center and ask them.
da
Worthless video for lights that stay on after all 5 tires are aired up. Video says “take it to the dealer for service".
da
Aggiungi la tua risposta
Janek Lachkovich sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 13
Ultimi 30 giorni: 56
Tutti i Tempi: 6,383
