Salta al contenuto principale
6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
Impossibile visualizzare l'opzione Wipe data / Factory in modalità di
Hi everyone, Please help me. I thought, once I entered recovery mode, I will use Wipe Cache to reset my Nexus 5X.
When I enter this mode, I do not get anything like that. I use the following guide to access the recovery mode:
https://techshali.com/enter-recovery-mod...
I am sure these options should be there in the recovery.
I have to flash custom restore or anything that could be done.
Any help is appreciated
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi ,
What are you getting when you try to enter the Recovery mode?
Are you pressing all 3 buttons together (i.e. Volume Up + Volume Down + Power) to get to the option to select Recovery mode?
da
Aggiungi un commento
1 Risposta
Almost sounds like you are getting the “No Command” android guy:
From this point you would hold down the power button and press volume up. Then you would enter the recovery menu where you can factory reset the device.
Punteggio 0
Aggiungi la tua risposta
Deepak Gupta sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 63
