Salta al contenuto principale
Released March 2016, 7.0" Galaxy Tablet by Samsung.
Media sound not working? SOLVED
Media sounds not working. Notifications & system sounds are fine.
Questa è una buona domanda?
Punteggio 13
9 Commenti
Thanks for the input guys. It's loud & proud again.
da
It's working again. Needed some down time I suppose. It's loud and proud once again! Thanks
da
Sounds goes up and down by itself
da
I have a problem of my new tablet A. It has no sound, i can’t hear any voice . All is set in settings but still no voice
da
I waited on my comment to be answered..
da
Mostra altri 4 commenti
Aggiungi un commento
3 Risposte
Risposta Più Utile
Also another thing to check is to make sure you do not have do not disturb turned on or turned on as scheduled. Depending on how it is setup it may mute all media sounds.
Punteggio 4
2 Commenti:
Thanks. It started working after I left it off for an hour.
da
Thanks... checked and it was my “Do Not Disturb” mode was on. Don’t know how it got enabled but it was in and fixed my problem.
da
If your tablet is anything like mine when you hit the volume keys there is a dropdown, maybe the media tab is all the way down.
Alternatively you could have somthing wrong in the system. I had a problem like this where i had to go to a boot menu and clear some temporary data on the
Punteggio 1
1 Commento:
Thanks. It started back up after I left it off for an hour.
da
Make sure it is not connecting to a Bluetooth device
Punteggio 0
1 Commento:
Thank you thank you thank you Malcolm, that was the solution for me. My tablet was connected with my hearing devices, which lay around somewhere in the living room.
da
Aggiungi la tua risposta
Richard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 22,948
